Flash Player
This is a discussion on Flash Player within the LG Ally Help forums, part of the LG Ally category; How does one install flash player so we can watch flash movies? I have read that flash is supported but can't find where to install ...
Thread: Flash Player
    Android Lurker emmacomeau's Avatar
    How does one install flash player so we can watch flash movies? I have read that flash is supported but can't find where to install the plugin.
    Flash is supported on Android 2.2. The Ally has 2.1 so its not supported. The best you can do for now is use the SkyFire browser.
    Android Lurker Bluedream102's Avatar
    Ok this is really bothering me. Alot of website are now supporting Flash Player and LG Ally doesn't support flash player. I called alot of companies to get answers and all i get is. Their will be a App to support it but no one seems to know when. Does anyone know when by any chance? For me this is a huge problem and i don't know if it is for you guys.
    Flash Player post.
does android ally support flash player
does the lg ally support flash?
doesn't support flash lg
flash player for lg ally
flash player update for ally android
flash player workaround for lg ally
how to get flash player to android 2.2 ally
lg ally flash player
lg ally flash player download
lg9 android flash player download install
new flash player for ally lg
overclock lg ally to run flash
overclocking the lg ally
watching movies on lg ally
