Before the update I was using handcent and my texts were blue and after the uptdate it doesn't work anymore which blows because I had certain people with different colors
Downloaded a couple apps to see if id work but nothing fixed it
This is a discussion on LED Status Lights within the LG Ally Help forums, part of the LG Ally category; Before the update I was using handcent and my texts were blue and after the uptdate it doesn't work anymore which blows because I had ...
