camera apk
This is a discussion on camera apk within the LG Ally Help forums, part of the LG Ally category; hi when i open my camera app, the camera looks completely black and white, but there are no effects on it. So, i was thinking ...
Thread: camera apk
    Android Lurker 9qwer1's Avatar
    hi
    when i open my camera app, the camera looks completely black and white, but there are no effects on it. So, i was thinking that maybe if i replace the old camera app with a new one, then it would fix the issue... so does anyone have the camera app apk?
    thanks in advance
    I don't think your going to find that. Even if you did you would probably need to be rooted. have you tried a simple reboot? If I were you I would do a factory reset.
android camera apk
camera open apk
camera open.apk
camera.apk
cameraopen apk
cameraopen.apk
decompile cameraopen.apk
how to fix lg ally camera
how to reset camera on lg ally
lg ally camera apk
lg camera apk
lgcamera android
replacing cameraopen.apk
the new camera apk
?????.apk
