help with txts
This is a discussion on help with txts within the LG Ally Help forums, part of the LG Ally category; I've installed handcentsms. My lg txt msg still comes up on the notification bar and the quick reply still comes up. How do I stop ...
Thread: help with txts
    Android Lurker sleepersubie's Avatar
    I've installed handcentsms. My lg txt msg still comes up on the notification bar and the quick reply still comes up. How do I stop the ally txt?
    Thanks
    Menu>applications>Messaging Once messaging is opened then... Menu>Settings>uncheck Notifications
    That will turn off the ally txt message in the notification bar.
    If you want to turn off the quick reply/pop up in handcent, that is done thru the handcent app under popup notifications.
    Open handcent>settings>notification settings>uncheck enable popup
how to turn on quick reply on an android ally
quick reply in notification bar android
