Extreme Death Cirlce - Need Help!!!
This is a discussion on Extreme Death Cirlce - Need Help!!! within the LG Ally Help forums, part of the LG Ally category; So, today I tried installing a new ROM ( a stock ROM, of all ROMs.. ) So, I install it successfully, and it boots. Yay, ...
Results 1 to 10 of 14
Thread: Extreme Death Cirlce - Need Help!!!
    Android Lurker old snoop's Avatar
    So, I install it successfully, and it boots. Yay, I just reset my phone! It looks brand new!
    But, I slide open the lock and EVERY single app force closes. I'd figure I'd try to go to recovery mode, BUT I CAN NOT ENTER RECOVERY MODE.
    All that shows is a little android logo guy with an error sign next to him.
    If I try to plug my phone into the computer, nothing happens. It doesn't pop up on my Ally, or my computer.
    So, basically, when I boot my phone, all I get is force closes. I can't get into recovery mode either, it just shows that ^^^^^
    I need help very much... I already had to get a new Ally already. Thank you
    When you flashed did you wipe data/cache/dalvik?
    Quote Originally Posted by Valkerie View Post
    Apparently I did not. Last time I did that I had to get a new phone... Idk, I just really need help. All I need to do is get into recovery mode to wipe all that cache and flash a good ROM, not a messed up one
    It sounds like you lost your root if you get the ! And android guy. Check out the Ally IRC. They can help.
    I need root to get into Recovery? All I need to know is how to get into recovery mode, then I'll be 100% good after I do a factory data reset....
    Recovery = send + menu + end while powering on the phone.
    All that does is give me an android with the ! sign...
    That means you do not have a custom recovery. You need to flash Amon-Ra or Clockwork recovery before you can boot to recovery. Amon-Ra is recommended.
    I have no idea how to do that if I can't even get that onto my phone. I can't use my phone because the force closes, and I cannot connect it to my computer. I have everything for it, but it won't let me
    You must not have flashed a new ROM if you don't know how to flash a custom recovery. Sorry to be a bit rude about it. Go to androidforums.com and ask around the "all things root" section and get on the Ally IRC.
ally doesn't boot into recovery mode
boot into clockwork recovery lg ally
how do i get an lg ally into recovery mode
how to reboot lg ally into recovery
how to restore lg ally to stock without computer
lg ally boot into recovery
lg ally boot into recovery mode
lg ally recovery mode
restore lg ally to stock without recovery mode
restore lg ally with computer
