text not ringing
This is a discussion on text not ringing within the LG Ally Help forums, part of the LG Ally category; all of a sudden my text notification is silent. I ahve checked the settings and the volume is on loud. Does anyone have any other ...
Thread: text not ringing
    Android Lurker jennifer29010's Avatar
    all of a sudden my text notification is silent. I ahve checked the settings and the volume is on loud. Does anyone have any other suggestions?
    Android Lurker leftygirl's Avatar
    Apr 2011
    crazy as it sounds...did you turn the phone off and turn it back on? Sometimes mine does that too
    Is your Ringer volume linked to Notifications? If not they each have a separate volume control.
    Could you Notifications ringtone be set to silent?
    Do your phone settings and App settings agree? Are you using the stock text App?
    All my sounds reset themselves today to something other than what I had them set to. Most got reset to a Homer Simpson sound that I forgot was even on my phone.
    Android Lurker champagne_paint's Avatar
    Whenever I notice that happens, I re-program my phone. I just call *228 and select option 1, it always does the trick, even when turning it off and then back on doesn't help.
android my texts are not ringing
android not ringing for text alerts
android not ringing when a text
android not ringing when i get a text
android noy ringing when i get texts
android phone not ringing for text messages
android phone not ringing for texts
android text not ringing
droid not ringing on text messages
droid not ringing text messages
galaxy s4 not ringing when getting text
lg ally isnt ringing
lg+ally+not ringing
message not ringing android
why is my android phone not ringing when i get a text message
