Help with contacts
This is a discussion on Help with contacts within the LG Ally Help forums, part of the LG Ally category; I have my Backup Assistant syncing my contacts every night (morning) at 12:30. Every morning I get a notification that the Backup Assistant has encountered ...
Thread: Help with contacts
    Android Lurker djbillbraun's Avatar
    I have my Backup Assistant syncing my contacts every night (morning) at 12:30. Every morning I get a notification that the Backup Assistant has encountered a database error. Please close BA and try again. Well I do try again and again and I get the same problem. I have turned sync off and turned off the phone and then turned it back on and tried syncing now. I keep getting the database error. Any solutions??
    2 times
    Give up on Backup assistant if contacts is all you are using and sync to gmail. That works for me.
    Thanks Sher - I actually did not know my gmail was automatically syncing anyway along with Backup Assistant so I did just turn off the autosync from BA.
    Android Lurker Holliebks's Avatar
    Easy to fix. Just go to settings, applications, manage applications, click the running tab, then select backup assistant, clear data, yes to clear data. Then you will be able to start over with backup assistant. Make sure you have your pin number ready. Good luck, it worked for me.
    Quote Originally Posted by djbill View Post
    jtm
    jtm is offline
    Android Lurker jtm's Avatar
    Mar 2012
    Its Simple, Just turn off Automatic sync for Backup assistant. You might have set schedule time for Backup assistant.
10 database error
10 database error backup assistant
backup assistant 10 database error
backup assistant database error
backup assistant database error 10
backup assistant error code 10
database 10 error
database error on backup assistant
droid incredible backup assistant database error
verizon backup assistant database error
verizon backup assistant database error 10
verizon backup assistant error code 10
verizon database error
what is database or 10 error
