Is it Bricked?
This is a discussion on Is it Bricked? within the LG Ally Help forums, part of the LG Ally category; OK, I my LG Ally is on 2.1 update 1 rooted, I tried to unroot my lg ally and it unrooted but it left the ...
Thread: Is it Bricked?
    Android Lurker marsblaster's Avatar
    OK, I my LG Ally is on 2.1 update 1 rooted, I tried to unroot my lg ally and it unrooted but it left the Superuser Permissions App, so i rerooted using Universal Androot but it failed, so i used SuperOneClick 1.5 (i think its 1.5) and its rooted but when a try to flash ANY ROM it gives me the Android guy with the exclamation mark. I want to go on stock and go to 2.2.... What do I do next?
    Two different ways you can do it. I've done them both and they both work:
    Revert to Stock: Method 1
    or
    Revert to Stock: Method 2
    Persoanlly, I'd go with Method 1 because it not only gets you back to stock, but also installs the stock recovery image which you will need to install all of the Verizon updates. Method 2 only gets you back to stock, but does not apply the stock recovery. That has to be flashed seperately.
bricked lg ally
bricked ouya
epub+reader android
how to flash a lg verizon sv740
how to unbrick android alley
lg ally bricked android forum
lg ally unbrick
lg enact bricked
reroot ally 2.1
root lg ally 2.1
root lg sv740 download
unbrick lg ally linux
unbrick lg ally stuck on dowloading
unbrick lg ally verizon
unbrick ouya
