Home screen changing on its own...
This is a discussion on Home screen changing on its own... within the LG Ally Help forums, part of the LG Ally category; My phone keeps changing things on its own. It will change the home screen types, move my apps, change the icon types, ect. The first ...
Thread: Home screen changing on its own...
    Android Lurker Tricia_Anne's Avatar
    My phone keeps changing things on its own. It will change the home screen types, move my apps, change the icon types, ect. The first time I thought it was just a strange thing and I turned the phone off then turned it back off…problem solved. Well now it’s doing it A LOT (like 2-3 times a day). And as of the last time it has not changed back to my settings even when I pulled the battery.
    Any help? ideas?
    I really wish phones were simple and easy....sigh....
    Thanks, Trish
    Open the app called Themes, it should be in your apps drawer. Make sure that only one theme is checked. Some users have noticed that 2 themes are checked and this causes the home to change.
    Normally, I would say search the forum because it has already been answered but in this case the answer is buried in another thread.
    You are amazing! Thank you.
    Trish
    Android Lurker smwilcox85's Avatar
    Jun 2011
    I just found out that my phone had both items checked as well, thanks!
android keeps changing settings
android phone screen changes by itself
lg g2 screen moving on its own
lg volt changes screens on its own
my android screen changes by itself
my home page keeps shifting on android
my home screen changed on my android
my home screen switched itself
why are my pictures changing on my home screen on my cell phone
why did my android home screen change
why did my home screen change
why did my phone change display by itself
why does my home screen keep changing
why does my lg homescreen keep changing to military time?
why would my phone be changing screens and apps on its own
