Wifi problems since froyo update
This is a discussion on Wifi problems since froyo update within the LG Ally Help forums, part of the LG Ally category; Hi All, Since receiving the 2.2 update Saturday I notice that my wifi disconnects and shows my network as "disabled" and I have to constantly ...
Results 1 to 10 of 17
Thread: Wifi problems since froyo update
    Android Lurker 2Di4Design's Avatar
    Hi All,
    Since receiving the 2.2 update Saturday I notice that my wifi disconnects and shows my network as "disabled" and I have to constantly reconnect manually. Anyone have any idea what's going on? My home network is secured and available, but my phone shows it as disabled. I've done a reset on the phone, same problem. It remembers the pass key and will sign on once I've told it to connect. I also have set it to never disconnect in the advance settings so not sure why it disconnects overnight and makes me reconnect manually.
    Android Lurker cromedome's Avatar
    Wondering if anyone else is having this problem and if anyone can help me with it. I updated to froyo last saturday nigt via OTA. Today is the first time i have tried to use wifi since the update. It says "unable to connect, connection failed, check network settings". It is connected to my wireless network at home. I had no problems before the update, just since the update. Hopefully someone can help me with this issue. Any suggestions greatly appreciated. Thanks.
    Did you start from scratch, delete the old network and create a new one?
    Android Lurker 1968_Roadrunner's Avatar
    I'm having a similar problem. Before the update my phone would automatically connect to any wifi network that I had saved in my phone. It won't do it any more. Every time I am out of range and then come back to a wifi network I have to manually reconnect. Is there a solution to this problem?
    I didnt see an option to delete. I just turned on the wifi and it showed my network so i clicked on it and typed in the password, it connected to my network and when i went on the browser it just said network connection error.
    im not having a problem connecting to my network, it connects no problem, i just cant get on the net even though it is connected
    Long-Touch the Network information and "Forget" it.
    In advanced settings (hit Menu), ensure "Use Static IP" is NOT checked. (Wi-Fi Sleep Policy is where you can set WiFi to Never, too).
    Now connect again and re-enter your Network Info. If you don't see your SSID touch Add Wi-Fi Network.
    You may need a power cycle if it does not work immediately.
    crome, are you sure your Router/Firewall is not interpreting this software version as a new device that needs permission?
    There's an app called WiFinder that might help. I used it before the update.
    Did everythig you suggested and powered on and off and tried again and WA-LA it worked. Thanks alot for your help Quasar. Greatly appreciated
    I've deleted "forget" the network. I even did a factory reset on the phone which wiped it. It is still consistently disconnecting from the wifi and saying it's available but "Disabled".
android ally wifi error
android ancore error lg help
froyo wifi fix
lg 855 wifi error
lg ally unable to scan for networks
lg ally used via wifi disconnects
lg ally wifi error
lg ally wifi problems
lg ally wont connect to wifi
lg phone wifi disabled
my lg ally won't connect to wifi
my lg ally wont scan wifi
unable to scan for networks lg ally
why wont my lg ally connect to wifi
wi fi not workung on lg ally
