FroYo Contact Display Options Have Changed
This is a discussion on FroYo Contact Display Options Have Changed within the LG Ally Help forums, part of the LG Ally category; I recently factory reset my phone. My contact list went from hundreds down to 23. However, when i type in my "old contacts" phone number ...
Thread: FroYo Contact Display Options Have Changed
    Android Lurker gilly6868's Avatar
    I recently factory reset my phone. My contact list went from hundreds down to 23. However, when i type in my "old contacts" phone number they are still there. When i do a name search in contacts "search all contacts" comes up and all my contacts are there too. I tried to import them but it wont work. Any idea how to get them back?
    thanks
    g
    Have you checked your settings in Contacts? These options have been enhanced since FroYo. Go to the Contact Tab, press Menu, touch Display Options. Touch the Account associated with the contacts you want to display. Check off the Groups you want to include (only My contacts is checked by default so if your contacts are not under My contacts they will be hidden by default).
    That did it.
    thanks
    G
    Android Lurker D_Marx's Avatar
    I know that there's probably a thread for this, and I want this phone to work. My phone is synced up to FB and GMail, but I came home from the store with none of my phone contacts in place. I bought this phone to be a phone that just happens to have internet, not a replacement laptop that can make calls if you just re-add the friends you can't remember the numbers to.
    I am lost. I have friends on here that are on here for a reason, and I need to talk to them. So how do I get these numbers from my Hue II to my LG Ally without manual labor?
    2 times
    I just saw another thread with this question yesterday and the answer was something to do with the settings for which contacts were to be displayed. Sorry I don't remember exactly what but I do know the answer was posted, so hopefully you can find it and use it.
    Merged.
    Your answer is above.
android contact display options
android contacts display options
contacts on lg froyo
display contacts in froyo
froyo changed my display
froyo view contact numbers
group contacs in froyo
how to group contacts in android froyo
how to make contact list at android froyo
my contact froyo
my contacts froyo
mycontact froyo
mycontacts froyo
mycontacts froyo group
mycontacts froyo groups
