Cannot Hear Calls
This is a discussion on Cannot Hear Calls within the LG Ally Help forums, part of the LG Ally category; Originally Posted by sherongb To the person who has named him/her self with the title of this thread: I can understand being frustrated when you ...
Results 11 to 20 of 22
Thread: Cannot Hear Calls
    Quote Originally Posted by sherongb View Post
    To the person who has named him/her self with the title of this thread: I can understand being frustrated when you have tried everything and nothing is helping. But from reading this thread the impression I get is that folks have been trying to help you, offering the simplest fixes (which often do get overlooked) first then when you say you have already tried that going on from there. But even from your first response I get the feeling that you are striking out at those trying to help you.
    Trying to trouble shoot any problem is a process. At this point I feel that folks are getting more and more reluctant to give you a reason to strike out at them for trying to help you. There may be a simple, or even a complex fix, out there, I don't know. But I do know that any person will only try to help and get slapped down a limited number of times.
    No one is saying you have not tried the suggested solutions. Sometimes we all try something and it doesn't work and someone else does what appears to be the exact same thing and it does work. Sometimes we are so used to doing something that we don't think about it and may skip one small step thinking we have done it.
    Perhaps at this point you would be less frustrated if you do take the phone back to Verizon and get a replacement phone.
    I am not saying your frustration is wrong, I am saying you have gotten so frustrated that you are not reacting as you would if you were not frustrated. Folks want to help you fix the problem. Please try to remember that.
    Well said and correct.
    To the OP: Try going to Verizon as it seems to be either a software or hardware issue only they can remedy at this point seeing as the usual process of troubleshooting has not helped.
    It is not what you said it is how you said it, Jack. So what if you consider this forum (and the Internet) impersonal enough to rant at someone trying to help you. If you took the steps someone suggested already, why not express them in your original post? Adding a link to a thread is more than enough help from someone volunteering information. The onus is on you.
    Good day. I hope VW can help you.
    Android Lurker spacetrain's Avatar
    Okay, so I am also having this problem. And after reading through all the bickering in this thread, i have come to the conclusion that the only actual fix is taking the phone into Verizon?
    Someone correct me if I'm wrong.
    Thanks
    Spacetrain,
    If you have no media sound unless you have a headset plugged in but you do still hear notification sounds, then the issue is software related. If you get no sound without plugging in your headset it is a hardware issue. For the first, I would do a factory reset. For the second, I would take it to Verizon.
    Thanks for the info. Also, Its probably not a permanent fix, but plugging headphones in and out a few times fixed it for now.
    Android Lurker Headphone Jack Problem's Avatar
    Well, I'm sorry if I was too abrasive to anyone here. At the store they tried taking the battery out, which didn't work of course, but then they instructed me to do a factory reset. So I did that, and that also did not fix the problem. Verizon tech support over the phone said it was likely a defective headphone jack and right away they put me on a course to get a replacement phone. So I did that.
    I do wonder though, is it a new phone that will come? The brochure that refers to this replacement routine says "certified like-new replacement" - What is a "like-new" ? It would be a real shame if I didn't get a new phone to replace this because I've only had the phone just over a month.
    Quote Originally Posted by Headphone Jack Problem View Post
    Certified-like new means that the phone was opened/used and returned and went back to QA inspection/testing at the factory and once it passed all of their checklists, was then stamped as ready to be put out to circulation once again. Sometimes it is indeed fixed and sometimes the problem resurfaces under regular use. They will not divulge what the original issue of the certified-like new was, or if it was just an *open box* phone that legally can no longer be sold as *NEW* but was never actually used by anyone. It also retains the original warranty unless otherwise noted. It is pot luck kinda of a deal so good luck with that.
    BTW, almost all companies follow this Certifed-like new system. I know of one from personal experience that does not. Computer builder DSO. They replace any part with only NEW IN BOX (NIB) item of equal or greater value to the part being replaced: Digital Storm
    I would have to agree that what you will be getting is a phone that was opened and returned within the 1st 30 days or one that had issues and they "fixed" the issues.
    If it was a phone that was just released, you would have gotten a new replacement but since all they send is the phone without the battery and cover, they don't say that its new.
    Thanks for the feedback.
    Android Lurker sweetjane13's Avatar
    I am also having an issue where the phone rings and I answer it but there is no sound. The person calling doesn't hear anything and I can't hear them. I checked my settings and the phone is not on silent, the call volume is up to max, Bluetooth is off. The only way I can correct it is to reboot the phone. It started happening after the upgrade and now it happens every day. My husband has the same phone and he's not having this issue. It sounds like I should to a factory reset first and see if that works? (And I don't use headphones but I'm wondering if my problem is the same as this one).
  1. People cant hear me...
    By dvdman in forum Rescue Squad General
    Last Post: 12-25-2011, 02:21 AM
  2. I can hear sound over Bluetooth, but people can't hear me
    By christinereed in forum LG Ally Help
    Last Post: 06-07-2011, 04:44 PM
  3. How did you hear about LGAllyForums.com
    By JohnDroid in forum Introductions & Site Assistance
    Last Post: 04-09-2011, 11:11 AM
  4. No one can hear me talk...
    By sirbiggsalot in forum LG Ally Help
    Last Post: 10-06-2010, 05:52 PM
alcalet shine cannot hear the caller
android cannot hear callers
android not able to hear anything when calling someone or picking up a call?
cannot hear when dialing out checked volume on androud phone is at max
i cant hear when i call android
lg e980 can't hear me talk
lg flex can't hear the other person
lg k10 can't hear phone calls
lg k10 every time i put speaker on the other person cant hear me and i get muted
lg phone cannot hear calls unless bluetooth is plugged in
lg phone cannot hear incoming calls
my lg android phone dials numbers, but i cannot hear anything
unable to hear only on speakerphone android lg g2
when i call someone on my lg g4 phone i cannot hear ringing just hear person answer
why cant i hear my phone calls stylo 2
