Issues since Froyo
This is a discussion on Issues since Froyo within the LG Ally Help forums, part of the LG Ally category; Hey all, My fiance has an LG ally and installed 2.2 as soon as the OTA was released to her phone. Since then she has ...
Thread: Issues since Froyo
    Android Lurker jlwoodman21's Avatar
    Hey all,
    My fiance has an LG ally and installed 2.2 as soon as the OTA was released to her phone. Since then she has been having a few issues.
    1. Her apps seem to force close quite often
    2. On her hardware keyboard, pressing Y or B or a few others will launch an app (youtube, the browser). This happens without her pressing the search key and they only way to make it stop for a day or so is to reboot.
    3. Her keyboard will start off in all caps at random when typing a text message.
    She only has about 8 apps installed and some of those were moved to the SD card, so it isn't a space issue. What are some options to fix the problem here?
    Its good practice to do a factory reset after you get the Froyo update.
    Android Lurker baldbrian's Avatar
    Do the factory reset. The random opening of apps is because of the quick launches feature. Here's a page that will help you with it:
    http://www.allyandro...quicklaunch.php
