Preparing SD card
This is a discussion on Preparing SD card within the LG Ally Help forums, part of the LG Ally category; You can do as you suggested, "turn the phone off, remove the card and replace it, then start it back up." I am not sure ...
Results 11 to 13 of 13
Thread: Preparing SD card
    You can do as you suggested, "turn the phone off, remove the card and replace it, then start it back up." I am not sure why your format froze. This could all be evidence of a corrupt card, even the camera not working before the update. Sorry.
    However, because your card worked for a second, there might be hope. It does not make sense to work sometimes. If it still does not work I would try formatting the SD Card in a computer SD Card reader. This is because I would get a report I understand, and if the card is corrupt you should get a clearer indication. If you do format in a computer, remember you need to format in the Phone again (they are different operating systems). Good Luck.
    Android Lurker mwn3d's Avatar
    Charlotte, NC
    No dice on that attempt. I can go to the Verizon store tomorrow. I don't have another way to read this SD card. I bet they have a way to format it for me there. If that doesn't work then I'll try a new (bigger) card (but not more than 16GB apparently).
    Thanks for your help guys. I wish all support forums could be this good.
    Charlotte, NC
    I got a new card at the store, but they reset my phone so I lost lots of stuff. I'm using the Backup Assistant from now on. Thanks again for your help!
android preparing sd card
lg ally no sd card
lg vortex preparing sd card checking for errors
no sd card or sd card is not ready
prepare sd card for android
preparing sd card
preparing sd card - checking for errors
preparing sd card android
preparing sd card checking for errors android
preparing sd card checking for errors galaxy s3
preparing sd card checking for errors stuck
preparing sd card for android
preparing sd card stuck
preparing sd card(checking for errors
