Power Control Widget
This is a discussion on Power Control Widget within the LG Ally Help forums, part of the LG Ally category; I needed to reset my Ally because since the update last week my phone freezes for no apparent reason. I would like help getting the ...
Thread: Power Control Widget
    Android Lurker ineedtorest's Avatar
    I would like help getting the (?) status bar back on my home screen
    I am probably using the wrong word but if you go to page 35 of the ally manual or (page 37 on Adobe) I attached a picture of it.
    I want that bar back which you see on top of the page page 4 of the home screen picture
    http://cache.vzw.com/multimedia/mim/lg_ally/ally.pdf
    Everything was so nice before the update. [attachment=47:ally question for forum.doc]
    Attached Files Attached Files
    I am going to assume that you mean the Power Contol widget.
    Just long touch your home screen where you want it. Touch widget. Find Power Control and touch it.
    Thanks for your help
    If I knew what it was called my question would have been clearer.
    Thanks for understanding what i meant
android power bar widget symbols
android power control widget faq
android power control widget reset data
android power help
android power widget symbols
icons on lg ally power bar
lg power bar
lg power bar icons
motorola android icons, power bar
motorola droid power control widget symbols
motorola power bar widget
motorola power control icons
power bar icons on lg phone
power bar lg ally icons manual
symbols on motorola power control
