bluetooth sound quality
This is a discussion on bluetooth sound quality within the LG Ally Help forums, part of the LG Ally category; Since the update my plantronics 975 sound quality has changed drastically, it used to be crystal clear, right after the update it started cracking and ...
Thread: bluetooth sound quality
    Android Lurker mrbghio's Avatar
    Since the update my plantronics 975 sound quality has changed drastically, it used to be crystal clear, right after the update it started cracking and skipping, I uninstalled it did a battery out reset and reinstalled it, still terrible, now what? I spent good money on the plantronics and would like to use it. Any help would be appreciated.
    sia
    sia is offline
    Android Lurker sia's Avatar
    Quote Originally Posted by mrbghio View Post
    I've exactly same problem after 2.2 update with Plantronics Voyager Pro headset. I've tried my old Plantronics Discovery 925, and it does not have the problem.
    --igor
android bluetooth audio quality
lg ally bluetooth audio out quality of sound
my bluetooth sounds quality changed
voice quality ally
