turn off GPS, WIFI etc...
This is a discussion on turn off GPS, WIFI etc... within the LG Ally Help forums, part of the LG Ally category; I have been reading thru the site and I see that many posters say to turn off GPS and WiFi, but I am new to ...
Thread: turn off GPS, WIFI etc...
    Android Lurker bigdlb12's Avatar
    I have been reading thru the site and I see that many posters say to turn off GPS and WiFi, but I am new to this phone and dont know where to go to do this, plz help
    also, what other items can I turn off to help preserve my battery life, I know not to turn off sync
    thank you in advance
    Quote Originally Posted by bigdlb12 View Post
    ok I turned off bluetooth and Wifi, but how to I turn off GPS, thanks
    In my opinion there is no reason to turn off GPS. GPS is only running when you launch an app that uses location like driving navigation. When you see the satellite icon in the notification area then GPS is running, if you dont see the icon then GPS is not running and not using your battery.
    A couple of days ago I had the sat icon running when I wasn't using any app that required it. I checked my settings and GPS was turned off but the icon was still there. I never did figure out what caused it. I had to reboot to clear it.
    To the OP, I use the power widget to control WiFi, GPS, Bluetooth, and Sync.
    Use the Power Control Widget. To put the Widget on a home screen long-touch the home screen and follow the prompts.
    The 5 icons on the Widget are WiFi, Bluetooth, GPS, Sync and Brightness, respectively.
    Even the manual and the internal phone menus suggest turning off GPS when not in use.
    thank you all for your help, I got it
gps icon on lg phone
how do i turn my gps off on my lg android cell phone
how to turn gps off on lg phone
how to turn off gps icon on lg 800
how to turn off gps on lg motion
how to turn off gps on lg vs 910
how to turn off my google gps on my lg motion
how to turn off the gps on lg phone
how to use gps on lg 34c
lg 34c cell phone forum
lg 7 tab turn off wireless
lg motion turn off gps
satellite symbol on android phone
turn off gps android 4.0
turn off gps on lg ally
