Phone won't turn on
This is a discussion on Phone won't turn on within the LG Ally Help forums, part of the LG Ally category; I was using my phone like normal, texting and had just got off the phone with my boyfriend. Set the phone down and went to ...
Thread: Phone won't turn on
    Android Lurker meharb's Avatar
    I was using my phone like normal, texting and had just got off the phone with my boyfriend. Set the phone down and went to pick it up and it was off. Tried to turn it back on but it wouldn't. Full battery when this happened. Popped the battery out and back in and nothing. Plugged it into the charger but nothing is happening.... How do I get my phone to turn on?
    There are 3 degrees of reset. 1.) Restart the phone. 2.) Remove the battery then after a few seconds, replace it (A "hard reset"). 3.) Factory Reset. FR clears your phone to "Out of box."
    These methods are usually where to start with this kind of recovery. Search "Factory Reset" to learn more about it because it will wipe all of your information on the phone.
    I have a black screen. There is no vibrations, noises, or responses when I push any of the buttons. I can't restart my phone if my screen remains black.
    From off, to factory reset hold down Volume Down + Menu + Power for a few seconds.
android phone won't turn on
android won't turn on
androud lg wont turn on
lg android phone won't turn on
lg phone won t turn on
lg phone won't turn on
lg phone wont turn on
lg smartphone won't turn on
my android lg phone won't turn on
my android phone won't turn on
my android won't turn on
my lg phone won't turn on
my lg phone wont turn on
phone won't turn on
phone wont turn on
