Running sloooow
This is a discussion on Running sloooow within the LG Ally Help forums, part of the LG Ally category; After getting Froyo, it was all great for a few days. Then I had a few calls not hanging up. So I did a factory ...
Thread: Running sloooow
    Android Lurker Kstone's Avatar
    After getting Froyo, it was all great for a few days. Then I had a few calls not hanging up. So I did a factory reset. I only downloaded a few apps, literally, like 3 or 4 and have since uninstalled Weather Channel, because after it's update, its not opening anymore. Anyways, now (the past couple of days) my phone is EXTREMELY slow when going to a new screen or opening anything. I just did the FR like a week ago so I don't know what's going on. Any advice? Thanks!
    Android Jr Member jazz's Avatar
    Quote Originally Posted by KStone View Post
    has it been awhile since you formatted your SD card?
    I updated to 2.2.1 using the LG update software, did a factory reset & formated my SD card then I put back on all my apps and my Ally now runs better than it ever did with 2.1.1 imho
    Android Lurker emarlatt's Avatar
    froyo will slow the ally because of all the additions. The best thing to do is to root the phone and install a kernel with a clock doubler to speed the phone up. I have mine rooted and I am running velocity 1.0. http://androidforums.com/trident/270...st-stable.html Rom. Wich has that type kernel in it phone moves very fast. I rooted it with the trident guide. http://androidforums.com/ally-all-th...oot-users.html guide
    Android Enthusiast cd_fifty_6's Avatar
    Overland Park, Missouri
    7 times
    @milkmac9
    I also have mine rooted with velocity and overclocked at 787mhz
    Motorola Droid RAZR MAXX - Droid X2
    7 times
    @milkmac9
    I also added launcherpro and now it runs like a dream. really smooth. you can root it with an application. called gingerbreak. u can download it from. www.4shared.com
android running slow factory wipe
lg -d500 running very slow
lg ally is running slow
lg ally really slow
lg ally running slow
lg ally slow
lg ally slow running
lg intuition running slow
lg2 runs very slow
lg730 running really slow
my lg ally is running slow
my lg intuition is slow
my lg phone is running slow
my lg phone is super slow
my lg vista is running very slow
