GPS Help please
This is a discussion on GPS Help please within the LG Ally Help forums, part of the LG Ally category; Is there a way to turn on voice to give driving directions? I know how to enter information, but don't know how to activate a ...
Thread: GPS Help please
    Android Lurker anniesgrammie's Avatar
    Is there a way to turn on voice to give driving directions? I know how to enter information, but don't know how to activate a voice to give directions while driving. Thank you.
    If you use Google Navigator, when you first launch it, there is an option to touch called "Speak Destination".
    Super Moderator sherongb's Avatar
    2 times
    If what you are saying is you don't hear any directions as you are driving I would suggest you make sure your volume is turned up. Go into the program and once you have the maps showing raise the volume then. It should say navigation volume. Make sure that is turned all the way up. I know I am able to change the volume of different things depending on what program I am in and it doesn't affect the volume in other areas.
    If you want to tell the GPS where you want to go by speaking then what Ally said should do it.
    I recall after I upgraded to Froyo, the first time I launched Navigation I was prompted that I need to download and install TTS or I would not have voice guidance. Perhaps you were given this prompt and inadvertantly declined the download??
    Thanks Marioval, Downloading that seemed to fix the problem. Will have to try it out today!
android speak destination not working
droid gps voice directions not working
droid navigation turn on voice
gps voice directions not working on lg ally
how do i activate gps on lg android phone
how to enable gps on droid ally
how to get map directions lg ally
how to turn on gps on lg -p500
how to turn on gps on lg ally
lg ally gps not working
lg gps activation for android
turn on voice driving on droid
voice directions to do not work on gps on droid
