Suspend Notifications During Call
This is a discussion on Suspend Notifications During Call within the LG Ally Help forums, part of the LG Ally category; Is there a way to suspend text, email, etc., notification rings and vibration while on a call? It drives me crazy. I get a ton ...
Thread: Suspend Notifications During Call
    Android Lurker scottyhuff's Avatar
    Is there a way to suspend text, email, etc., notification rings and vibration while on a call? It drives me crazy. I get a ton of notifications and it makes it almost impossible to concentrate on the phone with the thing buzzing in my ear. I don't want to change anything about my notifications otherwise, just when I'm on a call. Can anyone help with this?
    Thanks!
    I don't know if it will work, but you can try entering silent mode. Silent mode is supposed to disable all notifications except alarm. You may need to turn off "Vibrate-Always" if that is on, too. I imagine, you would need to create a shortcut on your home screen (even with Power not enabled to hang-up the phone I am not sure how holding power will react). So, enter the call then hit home, then hit the Silent shortcut. You should still be on your call.
    NOTE: I usually have my phone to test this but it is being repaired.
android notifications during call
android suspend notification
android turn off email notificaiotn vibration while on phone
android turn off notifications during a call
android turn off notifications during call
email notifications while on the phone android
i want all notifications off except alarm on galaxy note
notification while call android
stop notification during call lg
suspend notification sounds for email
text notification during call android
text notification while on phone droid
turn off email notification during calls on android
turn off notification on s3 while on a call
