Ok, I've managed to pair with another bluetooth device (another LG Ally); the status says I'm paired but not connected. How do I connect to it ?
In the manual it says that if you touch and hold the device under the list of devices an option menu will show... the only option menu that shows for me is Unpair and Incoming Security, that's it.. nothing more.
HELP !
Thanks.
