Adjusting vibration
This is a discussion on Adjusting vibration within the LG Ally Help forums, part of the LG Ally category; Is there any way to increase the intensity of the vibrator? Even with the phone in my pocket, I can barely feel the phone vibrate. ...
Thread: Adjusting vibration
    Android Lurker Paawpabear's Avatar
    Moore, Ok.
    Thanks;
    Ken
    Android Lurker boone1989's Avatar
    I had a similar problem, mostly solved by downloading Handcent. It has an option to customize the vibrate, and I have it vibrate on 3 long and then I usually notice it.
    Moore, Ok.
    Quote Originally Posted by boone1989 View Post
    Thanks for the heads up. I went to the market and found multiple Handcent apps, which one should I be looking for?
android increase vibration intensity
droid adjust vibration
droid razr increase vibration
droid razr m vibrate intensity
how do i increase the vibration on my droid razr
how to change vibration on droid razr
how to increase phone vibration
how to increase the vibration on droid razr
how to increase vibrate on droid razr m
how to increase vibration on android
how to increase vibration on android phone
increase vibration intensity droid razr
phone vibrate increase
vibration intensity on droid razr
