Setting Default Messaging
This is a discussion on Setting Default Messaging within the LG Ally Help forums, part of the LG Ally category; Hello Im just trying to figure out how to set handcent as my default messaging app.. And is there anyway to turn off the regular ...
Thread: Setting Default Messaging
    Android Lurker Mr.Swoopy's Avatar
    Hello Im just trying to figure out how to set handcent as my default messaging app.. And is there anyway to turn off the regular messaging notifications? So I dont recieve 2 different notifications? 1 from the default.. And 1 from the handcent messaging.. Thank you very much in advance
    Android Lurker Difalco's Avatar
    That's a good question that I'm working on.. and was hoping someone else already had it figured out LOL
    Please do a search of the forums for handcent. This problem has been solved and discussed multiple times.
change default messenger android
change look of messenger on android
handcent default messaging for spectrum
how do i make handcent my default messenger
how do you get handcent to be the other messager on lg spectrum
how to change default messenger in android
how to change default messenger on android
how to make handcent default messenger
how to make handcent default messenger on android
how to make handcent default messenger on droid
how to set default messaging android
how to set default messenger android
how to set default messenger on android
how to set handcent as default on android
make handcent default messaging app
