3g icon replaced by triangle
This is a discussion on 3g icon replaced by triangle within the LG Ally Help forums, part of the LG Ally category; I recently received a replacement LG Ally phone for my old one in which the speaker was broken. When I placed the battery and SD ...
Thread: 3g icon replaced by triangle
    Android Lurker mneuman's Avatar
    Apr 2011
    I recently received a replacement LG Ally phone for my old one in which the speaker was broken. When I placed the battery and SD card into my new phone, where the 3G icon is, there is rather a black triangle. I have no access to 3G on the new phone and do not know how to set it up. When I put the SD card and battery back in my old one, the 3G works fine just like before. Any suggestions on how to handle this?
    Did you activate the EIN at Verizon.com/My Account (or call VW)? Then call *228, and press option 1 to activate.
    Apr 2011
    thank you very much, that solved the problem!
    Junior Member Drink's Avatar
    Post Backup SMS from Sprint Android Phones to Computer
    Hello all, I share this Android SMS Backup app for the Sprint Android Phone users here. Hope it helpful.
    VeryAndroid SMS Backup is a smart andriod sms backup software that can copy and backup sms on Android phone to computer, restore sms backup file to any android phone, and also send messages or chat with a friend on computer directly, exactly the same as that you do on your android phone.
    It can help you:
    - Copy and backup sms from Anroid phone to computer.
    - Restore sms from CSV to android phone any time.
    - Send SMS & SMS Chat on computer directly.
    - Transfer sms to android phone from other phones (iPhone, Windows Mobile, Nokia, Blackberry etc).
    - View sms messages in threading mode on computer.
    Junior Member brucecat23's Avatar
    How to backup SMS from Sprint Android phone to computer
    Hello,
    Sprint Android phone is a smart phone. Sprint Android phone is widely used by many people all over the world.
    However, many users want to backup their SMS from Sprint Android phone to computer for keeping their important SMS. Here I recommend an Android SMS Backup tool to you. You can refer the article - Backup SMS from Android to PC to use it to complete your SMS backup.
android phone triangle symbol
android triangle icon
meaning triangle in the lg ms770 phone
my lg ms770 has a triangle icon at the top
the triangle where the 3g be
triangle icon android
triangle icon on android
triangle instead of 3g
triangle symbol android
triangle symbol on android
triangle symbol on android phone
triangle symbol on lg phone
verizon triangle symbol
what does it mean when a triangle icon appears on my lg ms770
what is the triangle symbol on android
