Using the phone without a battery
This is a discussion on Using the phone without a battery within the LG Ally Help forums, part of the LG Ally category; Hello, after not getting answers or any sort of help on other android forums, I figured I'd come pick you guy's brains. My battery took ...
Thread: Using the phone without a battery
    Android Lurker nickconforti's Avatar
    Apr 2011
    My battery took a dump and I was curious if there is a way to prevent the phone from shutting down without the battery installed.
    Or if I could circumvent the use genuine battery message altogether, and not have to replace it, that'd be awesome too.
    The battery holds a charge and powers a crappy Metro LG that takes the same battery.
    Any ideas?
    It depends on the phone. The only way to tell would be to connect the charger and then remove the battery. If the phone stays on, you are good but you would have to keep the phone connected at all times. If not, the phone won't work without a battery.
can you start a cell phone without a battery
how to turn a phone on without a battery
how to turn on a phone without a battery
how to turn on a phone without the battery
how to turn on android phone without battery
how to turn on android without battery
how to use a phone without a battery
how to use android without battery
how to use phone without battery
turn on lg phone without battery
turn phone on without battery
use android phone without battery
