checking call message
This is a discussion on checking call message within the LG Ally Help forums, part of the LG Ally category; when i go to check my 'messages' i hit the dialpad so i can type in my code... the dialpad will turn on then off.. ...
Thread: checking call message
    Android Lurker dugmqdugmq's Avatar
    Apr 2011
    when i go to check my 'messages' i hit the dialpad so i can type in my code... the dialpad will turn on then off.. then comes back on.. then as i go to push the #'s again it goes off... it's frustrating cause i can't punch in code #... this is an intermittent problem... but happens enuf to be very annoying... any input on why it does this???
    thx
    dugmq
