Half of my screen is unusable...HELP!?
This is a discussion on Half of my screen is unusable...HELP!? within the LG Ally Help forums, part of the LG Ally category; Hello, and thank you for reading my post I woke up this morning to this on my LG Ally's screen: That grayed out box at ...
Thread: Half of my screen is unusable...HELP!?
    Android Lurker cjdrums's Avatar
    Apr 2011
    That grayed out box at the bottom won't go away no matter what I do. And it's disabling half my screen, the buttons on it don't do anything, and it disables the buttons on my phone, so I can't use the home, back, search, power, call, or menu buttons.
    Can someone help me!?
    2 times
    Two things I can thing of to try: Turn the phone off, leave it off for 5 - 10 seconds then restart it. See if that fixes it. If you can't power off open the back and remove the battery, leave it out for a few seconds, then replace and restart the phone.
    Also it looks like the phone/browser/menu button has moved up on the screen. Try long pressing it and see if you can then move it back to the bottom of the screen.
    Also you might try going back to the stock home screen and see if that helps.
    If none of those work let us know and maybe someone else will have some other ideas.
    Android Enthusiast cd_fifty_6's Avatar
    Overland Park, Missouri
    7 times
    @milkmac9
    looks like a good virus you got. I guess lookout failed
    Motorola Droid RAZR MAXX - Droid X2
    Antivirus apps are about useless on an Android phone. I don't use one and have never gotten a virus. It is when users download apps that ask for permissions they don't need that they get viruses. Or if they allow auto updates in the market. An app could be legit when first installed then maleware is added to an upgrade.
android bottom half of screen has buttons
android bottom half of screen is grey
android bottum half of screen not working
android half of screen doesnt work
android half screen does not work
android phone bottom half of mail screen gayed out
bottom half of droid screen has menu on it
bottom half of screen unusable with large icons windows 7
grey half screen android
help half of my android screen does not work
my android screen is grey hel
square box at the bottom of my lg andriod
the top half of my android wont work
top half of screen unusable
why is the bottom half of my phone screen grey
