Ringtones
This is a discussion on Ringtones within the LG Ally Help forums, part of the LG Ally category; How do I download different ringtones?...
Thread: Ringtones
    Android Lurker Mabelle71's Avatar
    Android Jr Member OneFore9's Avatar
    MP3 files can be used for ringtones and notifications. If you set up the SD card with /Media/Ringtones and /Media/Notifications directories, you can drag and drop MP3 files to each. Once in these directories, they will show up in the dropdown menus (Settings, Sounds). Look here for a guide for setting up the SD card:
    File structure
best ringtone app for lg ally
