Register
Phone screen not working
This is a discussion on Phone screen not working within the LG Ally Help forums, part of the LG Ally category; My nephew was playing with my phone and accidentally dropped it in some water, now the screen won't work at all when it's turned on. ...
+ Reply to Thread
    Android Lurker amahri's Avatar
    My nephew was playing with my phone and accidentally dropped it in some water, now the screen won't work at all when it's turned on. Is there any way to fix it? I really don't want to pay 90 dollars for a replacement phone.
    be sure it is off and remove the back cover and the battery - let them air dry with the battery compartment sidedown - if you can, keep it near a slightly open window (in dry cool weather) - keep it this way for at least 2 or 3 days without touching it - then replace the battery and the back cover and try turning it on - since it isn't working now, you have nothing to lose but can hope. I have had several phones in my life drop in toilets, sinks with running water, and on concrete in pouring rain and after using this method, have been one lucky gal with no ill effects. Good luck!
    as a side note: under the battery compartment is a small white rectangle box...in a phone that has never seen moisture it will be plain white, in a phone that has been wet, you will see red/pink XXX marks - this is to let reps and techs know if your phone has water damage. It isn't always fair tho, as moisture from body heat might might also cause them to appear.
    The screen hasn't worked for over a month =/ phone turns and everything i just cant see anything on the screen.
Sponsor
  1. Activation for new phone not working
    By kmcnamara in forum LG Ally Help
    Last Post: 08-29-2011, 09:29 AM
  2. New phone, cracked screen
    By DarkJackWolf in forum Motorola Triumph
    Last Post: 08-16-2011, 05:26 PM
  3. Sharp Working On A New Android Phone
    By WenWM in forum Android News
    Last Post: 06-02-2011, 10:05 AM
  4. Home & Phone Keys not working
    By mnortman in forum LG Ally Help
    Last Post: 05-19-2011, 02:54 PM
  5. Replies: 0
    Last Post: 02-18-2011, 12:57 PM
android phone screen not responding
android screen not responding
android screen not working
droid phone screen not working
droid screen stopped working
lg ally screen not working
lg ally touch screen not working
lg phone screen not working
my android screen wont work
my lg ally screen wont work
phone screen stopped working
why is my phone screen not working
