Phone Screen
This is a discussion on Phone Screen within the LG Ally Help forums, part of the LG Ally category; Every few days my phone screen stops working.It shows as on but I cannot slide the pages or press on the Apps.I cannot even turn ...
Thread: Phone Screen
    Android Lurker jdomb's Avatar
    Phone Screen
    Every few days my phone screen stops working.It shows as on but I cannot slide the pages or press on the Apps.I cannot even turn it off. I have to remove the battery and reboot.
    Any solutions?
    190 times
    FurryVarmint
    Are you stock? If so, a factory reset may clear up what's gumming the system down. If not, try reflashing the ROM.
    Occasional lockups are part and parcel of the Android world, unfortunately.
    Before you do anything else, though, ask yourself if you've installed any apps recently that may have caused the problem. Oh, and are you rebooting every day/couple of days?
    DO NOT WRITE IN THIS SPACE
    I have not installed any new Apps. Is a reboot just removing and reinstalling the battery?I do that only when the problem occurs, usually every 4-5 days.
    190 times
    FurryVarmint
    Press the power button until the menu pops up, tell it to power the phone off, say yes, wait for it to shut off, and power it back up. This will clear the gunk out of the system, which is VERY important for older hardware and older versions of Android.
    Not sure what you mean. i have a talk app but cannot talk into my phone. Cannot even press on an app.
  1. Phone screen not working
    By amahri in forum LG Ally Help
    Last Post: 11-22-2011, 12:16 PM
  2. Screen not lighting up when phone rings, etc.
    By Jus1MooreMom in forum Rescue Squad Help
    Last Post: 10-14-2011, 10:58 AM
  3. New phone, cracked screen
    By DarkJackWolf in forum Motorola Triumph
    Last Post: 08-16-2011, 05:26 PM
  4. You must want to protect your cell phone screen well.
    By Navy0513 in forum LG Ally Accessories
    Last Post: 11-21-2010, 10:01 AM
  5. Phone Screen Problems
    By xtcvapor in forum LG Ally Help
    Last Post: 10-14-2010, 07:59 AM
android forums
black droid ally screen
lg ally not turning on
lg ally phone screen black
lg ally screen black
lg ally screen black problem
lg ally screen blank
lg ally screen not turning on
lg ally screen not working
lg ally screen not working black
lg ally screen problems
screen dark on lg alley
screen on phone is black lg ally
what do you if your android cell phone's screen stops working?
whats wrong with my ally phone screen dark
