SD Card Problem after System Update
This is a discussion on SD Card Problem after System Update within the LG Ally forums, part of the LG Android Phones category; After the last update to 2.2.1, my SD card keeps on ejecting its self or my device says I don't have on inserted, even though ...
Thread: SD Card Problem after System Update
    Android Sr Member jon_l85's Avatar
    wisconsin
    After the last update to 2.2.1, my SD card keeps on ejecting its self or my device says I don't have on inserted, even though there's one in. ???
    Sent from my Ally using Android.net App
    197 times
    FurryVarmint
    Try popping the battery out, waiting 30 seconds, then removing and reinserting the card. If the problem persists, first try cleaning the contacts on the card gently with a dry toothbrush, then try backing up the card's contents to your PC and reformatting it. If the problem still continues, try replacing the card entirely.
    wisconsin
    Ok thanks.
  1. Replies: 8
    Last Post: 03-27-2011, 01:45 AM
  2. Wi-fi problem
    By Jef-Droid in forum Motorola Droid X
    Last Post: 02-14-2011, 10:42 PM
  3. Post Thanks System replaced with Likes System
    By JohnDroid in forum Introductions & Site Assistance
    Last Post: 01-21-2011, 12:10 PM
  4. Replies: 11
    Last Post: 10-02-2010, 11:40 PM
android motorola xt907 sd card issue after update
android sd card problems update
android update keeps rebooting sd card
android update sd card
android update sd card problems
android updtator on sd
checking sd card update
droid keeps ejecting sd card
htc sd card issues after android updte
lg ally sd card problems
phone keeps ejecting sd card
samsung s3 android update sd card problem
sd card android update
sd card keeps ejecting
sd card keeps ejecting android
