This is an issue on my Ally. Went back to the Verizon store yesterday after having mine for less than a week. Told the rep what was going on with Cell Standby running 70-80 and Time w/o signal 97-100%. She just replaced it on the spot, no questions asked so at least here they sure seemed to know something they are not admiting to. Didn't change anything though, the new Ally is just as bad as the other one. My Stepdaughter has the Ally too and she doe not have this issue nor does my 2 stepsons, both have the HTC Eris and we're all running 2.1. My Ally will be down to 60% after only 4hrs with very little usage.
I'm not convinced yet this is strictly a "software" issue as we can lay all 4 of these phones down side by side on the table and both Ally's vary between 0-1 bar of signal and the Eris's will have 2-3 bars. While this clearly isn't scientific it does lead me to believe the Ally suffers from poor signal reception (at least compared to the older Eris's).
So now I wonder, ok so I have the "bug" in my Ally but how much of my "Time w/o Signal" is truly without signal since the Ally clearly has poor reception?? I've tried the 4636 fix and the APM fix, neither one does anything for me. I guess I'll just have to live with it and hope 2.2 fixes the "bug" although if we're are dealing with a hardware antennae issue, no software update is going to fix that.
Would that be software, hardware or both??? Bad reception or just bad "perceived" reception because of the bug (i.e an inaccurate signal strength gauge)??
Sigh, so many questions and so few answers lol..
oh, off topic for this thread but has anyone been able to sucessfully install the USB drivers from LG? The file LG gave me and the file I've found in my research, neither one are the "correct" usb drivers, at least according to Vista lol..
LinkBack URL
About LinkBacks
