Hi sammie,
First sentence, correct.
Second one, Gotcha, are you charging via AC, or USB at work? If AC, it should stay charged.
If USB, the state of charge can fluctuate depending on usage, but should stay mostly full.
Third one, perhaps, by not cycling the battery as much it doesn't get used as much. If you did that every morning, it might extend the overall life of the battery.
Think if you had 2 batteries, and traded them out once a week. They would both have a longer service life opposed to using the same battery all the time.
LinkBack URL
About LinkBacks
