Missing Widget, I think .. Help
This is a discussion on Missing Widget, I think .. Help within the LG Ally forums, part of the LG Android Phones category; I'm not sure how 2 ask or what it's really called so i'll describe what i did . I had a widget, (I think it ...
Thread: Missing Widget, I think .. Help
    Android Lurker luzzionz's Avatar
    I'm not sure how 2 ask or what it's really called so i'll describe what i did . I had a widget, (I think it was a widget) On one of my
    home pages it was a black Bar approx 2 inches across 1/2 inch tall and it would let you know if wifi was running or gps
    or blue tooth was running had like 5 different boxes .. now what happened i loved this easy way to set up bluetooth click it
    on and turn on the tooth .or GPS, no need to go into settings.. my problem is when i set it up originally i had it on my last home page
    and wanted to move it to the second swipe.. and in so doing you know what happened it got deleted .. and now I can't find it
    or even remember how i got it there in the first place.. the memory is the Second thing to go.. might be the first thing to go with
    me.. any ideas where to find this lovely tool ? I don't know what it was called or i'd do a search, i've spent the better part of last
    night and this morning looking for it . and here i am.. thx for looking HELP !! LOL ..
    Easy fix for ya...first, go to the screen you want that widget on. Next, long-press on the screen and select Widgets. The particular widget you are looking for is called Power Control. Select that and you'll be good to go.
    Quote Originally Posted by Vol4one View Post
    Thx Vol4one, It is now where I want it.. awesome ..never tried the long press before, use the settings/add ..thx again ..
    Go Vols
android missing widgets
android power control widget disappeared
android power control widget missing
android widgets missing
droid power widget missing
finding missing widgets
how to widget on lg ally
i lost my power contro widget
i lost my power control widget android
lg ally black bar
power widget missing android
widgets disappeared on lg spectrum
