LG Ally 2.1 Maintenance Release 9/17/10....Temp Pin
This is a discussion on LG Ally 2.1 Maintenance Release 9/17/10....Temp Pin within the LG Ally forums, part of the LG Android Phones category; Hello everyone, I have just been notified that the Ally will be getting an upgrade to a new software version ZVB. Please do not confuse ...
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: LG Ally 2.1 Maintenance Release 9/17/10....Temp Pin
    Hello everyone,
    Please do not confuse this with FROYO 2.2 Upgrade! This is a software update for features in the device NOT a OS update.
    The update will be done via GOTA (Google Over the Air), this means that the update will happen automatically, the same way the V08 update happened in the past.
    SW update start date: 9/17
    Schedule: Day 1 - 10K, Day 2 - soak, Day 3 - hold due to weekend, Day 4 - 100K, Day 5 - 400-500K (remaining)
    So by the schedule above, all Ally’s should receive updates by next Friday.
    Let me know if you have any questions.
    Android Lurker sneakyd's Avatar
    great news hope it helps
    Interesting. I'm going to reject the download until I hear some feedback from people.
    Android Lurker tabbicakes's Avatar
    This update is supposed to fix the problem I am having with power cycling. I hope I get the update soon!!
    The update should fix some of these issues:
    • Rebooting - ???
    • Outlook Sync - Overall enhancements.
    • Memory Issues - ???
    • Slugishness - Improved application response when opening from home screen.
    • Battery Lifetime - Enhanced battery life.
    • MicroSD Issues - ???
    • Camera Issues - Improved performance plus operate Gallery with improved speed and efficiency.
    • Android Security - Improved
    • PC Sync - Improved syncing between Ally and PC via USB.
    • Bluetooth - Enhanced ability to pair Ally with multiple Bluetooth devices.
    • Backup Assistant - Updated.
    • City ID - Added
    • Skype - Added
    • My Verizon - Added
    • Corporate Directory - Added
    Android Sr Member Dolfan0925's Avatar
    • Rebooting
    • Outlook Sync
    • Memory Issues
    • Slugishness
    • Battery Lifetime
    • MicroSD Issues
    • Camera Issues
    Wow. That's a pretty serious fix. Hope it actually does half of it.
    Android Lurker jay_jay's Avatar
    Ok so today I got a message saying I had a system update. I clicked get now and my phone just shut down. Thinking it was my custom rom I flashed back to ally stock v 2.1 and the update came again. Still wouldn't go. Error in clockworkmod says signature something. Any ideas?
    Android Lurker sdotreynolds's Avatar
    I am having many issues after the update this morning as well. Some Widgets are gone and applications are not working either.
    My phone shut down and did a restart with the software update. I had to uninstall and reinstall several widgets and apps.
battery rejected lg ally
battery upgrade for lg ally
hard reset lg 65166
lg 65166
lg ally battery rejected
lg ally bluetooth battery
lg ally camera issues
lg ally camera not working
lg ally maintenance
lg cell phones 65166
lg phone 65166
lg pin reset
lg65166
reset lg 65166
silverlight android
