Phone fades when using dial pad (for voicemail)
This is a discussion on Phone fades when using dial pad (for voicemail) within the LG Ally forums, part of the LG Android Phones category; When I call voice mail and open the on screen dial pad and begin entering my voicemail pin, the screen fades to black. Is there ...
Thread: Phone fades when using dial pad (for voicemail)
    Android Lurker nodscene's Avatar
    When I call voice mail and open the on screen dial pad and begin entering my voicemail pin, the screen fades to black. Is there a way to avoid this? Strangely it doesn't seem to do it every time, I try holding at different angles but I see no pattern as to when it does and doesn't do it.
    While playing around with it just now I noticed it fade when I put my finger very close to the screen, but not quite touching. It seems maybe it fades because it senses something being close as though you're talking into it (could it be that smart?)
    Anyway, this is extremely annoying, am I missing something here? I can't find any other discussion of this 'feature'
    Yes, you are missing the proximity sensor in the upper right corner of the screen, just right of the Verizon logo. Search "proximity sensor" in these forums to learn more.
    got it, thanks alot.
android phone screen flickers when using dial pad
dial pad does not work on lg lucid
how to use dial pad on lg nexus
lg call.pad not working for voicemail passworf
lg lucid dial pad
lg phone black screen voicemail
lg smart phone dail pad fades out
nexus 4 screen fade out when dialling
proximity sensor dial pad
voicemail dialpad fades
while talking on phone it gradually fades out why?
why does my droid dna fade in and out while i am talking?
why does my droids dial pad fade out during a call
why does touch screen in voicemail fade
why my android screen fade in and out on my dial pad
