how do you get the battery out
This is a discussion on how do you get the battery out within the LG Ally forums, part of the LG Android Phones category; I was just wondering in case somthing because I have a history of waterlogging...
Thread: how do you get the battery out
    Android Enthusiast cd_fifty_6's Avatar
    Overland Park, Missouri
    7 times
    @milkmac9
    Motorola Droid RAZR MAXX - Droid X2
    Android Lurker Noble_lgally's Avatar
    Quote Originally Posted by cd_fifty_6 View Post
    I am using an eyeglass screwdriver to lift out the battery.
    7 times
    @milkmac9
    How small is that
    The corner of a credit card works well.
    I would definitely use the soft plastic of a credit card over a metal screwdriver.
    7 times
    @milkmac9
    That sounds good. I water logged my old lg dare three times and it still works because I took everything out. The worst one was when I left it in my jeans pocket and it got washed
    I use my finger.
    7 times
    @milkmac9
    Good answer
hoe do you get an lg out of the case
how do i take out the battery on my android
how do i take the battery out of my tablet
how do you get the battery out of an android
how do you take the battery out of an android
how do you take the battery out of an lg android
how to get battery out of android lg s4
how to get out battery lg beacon
how to remove battery from lg beacon
how to remove battery lg ally
how to take the battery out of lg ally
lg ally battery removal
lg beacon battery removal
lg beacon remove battery
remove battery from lg ally
