Charging Battery
This is a discussion on Charging Battery within the LG Ally forums, part of the LG Android Phones category; Does it hurt the battery to leave it charging all night? Also should you let the battery run down before charging or can you charge ...
Thread: Charging Battery
    Android Lurker jdomb's Avatar
    Does it hurt the battery to leave it charging all night? Also should you let the battery run down before charging or can you charge it any time?
    Android Lurker sierratoucan's Avatar
    You should be fine leaving your battery charging all night, I do as much and my ally is fine. If you just got your phone you can let your phone run down before charging it, so that way you can condition your battery to have a better life.
    PS you can look up threads with battery, charging, conditioning, etc and you will find a million threads. People tend to get annoyed when there are repetitive questions posted.
    Hope this helps.. =]
charging battery lg
lg bl44j battery charging
