Register
need help with contacts
This is a discussion on need help with contacts within the LG Ally forums, part of the LG Android Phones category; I know this might have been asked, but in my contacts there are multiple listing for each of my contact, for example when I go ...
+ Reply to Thread
    Android Lurker bgarcher's Avatar
    Dec 2011
    Question need help with contacts
    I know this might have been asked, but in my contacts there are multiple listing for each of my contact, for example when I go to my daughters contact and scroll through it, it show phone #, address and e-mail about 5-10 times, is there a way to only have one? plus I have added new contacts that have now been deleted and I can't find them (even when I do export - import)
    Can some one help me.
    Bonnie
    Android Lurker ktklein72's Avatar
    So. Jersey / Philly
    ktklein72
    I know there is an option to merge multiple contacts into one contact. For instance if you have created a contact and then have a second one from Facebook, you can click on the 2nd one, go into to it to edit and then press the menu button - you should get a join option. From there you then select the other contact and then viola, where you once had two separate contacts you now have one. Joined contacts can be unjoined in the same manner. Now if you mean you are getting multiple entries under one contact, I'm not sure where that is coming from. Whenever I feel the need to clean up contacts, I do it from the Google website on my PC - I find that a far more efficient process. Perhaps when you changed phones, did the carrier transfer everything for you? Sometimes that process can mess things up.
    Dec 2011
    I even tried that, I was told that if contacts go missing then to export then import them back which make them all show up, but if you go under one contact it shows up about 4 or more times, and that what I want to delete is the multiple times it in my contact;
    Any advice?
    So. Jersey / Philly
    ktklein72
    The only suggestion I have is assuming all of the contacts are intact up on Google w/o duplicate entries, try deleting all of your contacts locally (turn sync settings off first and maybe even do it w/airplane mode on so all radios are off) and then let the phone pull everything down from Google again. Other than that I'm not sure. Good luck.
    Sent from my DROID X2 using Tapatalk
Sponsor
  1. Contacts
    By Lalita Sreenivasan in forum Sony Xperia X8
    Last Post: 06-06-2011, 02:11 PM
  2. facebook contacts and phone contacts
    By redfalcon302 in forum LG Ally Help
    Last Post: 12-16-2010, 01:41 AM
  3. ICE Contacts?
    By Ak8s_lgally in forum LG Ally Help
    Last Post: 10-16-2010, 04:17 AM
  4. Contacts help
    By Sanderling in forum LG Ally Help
    Last Post: 09-10-2010, 07:37 PM
  5. Contacts...
    By bksxxx in forum LG Ally Help
    Last Post: 08-28-2010, 05:33 AM
how to combine contacts on ally android
how to join 2 contacts on my lg allie
i added contacts to my lg ally and there not therw
lg ally contacts
lg android help contacts
lg phone joined contact
lg phone joined contacts
multiple contact entries on android
what is a joined contact
www.att lg androidnet
Tags for this Thread
