G2X Problems
This is a discussion on G2X Problems within the LG G2x forums, part of the LG Android Phones category; Yea I read that the other day. And unfortunetly my shutting off problem has not been resolved. People are saying rooting solves that problem but ...
Results 11 to 20 of 46
Thread: G2X Problems
    Android Lurker fcjasontt's Avatar
    Yea I read that the other day. And unfortunetly my shutting off problem has not been resolved. People are saying rooting solves that problem but I am going to see what T-Mobile thinks first. Just not interested in doing a factory reset. Considering the second I got into the car after purchasing it, it did it twice.
    Sent from my LG-P999 using Android.net
    Somewhere on Kamino
    83 times
    Return it. Should be within warranty.
    197 times
    FurryVarmint
    Take it back to T-Mobile. But do NOT even MENTION rooting or they may refuse service thinking you had rooted.
    DO NOT WRITE IN THIS SPACE
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Quote Originally Posted by fcjasontt View Post
    There's a service bulletin that LG issued for the random shut off problem. When you get T-Mobile customer service on the phone or take it into a store, ask them about it. They should replace your phone, no questions.
    But yea... like FBM said, don't mention rooting... That voids your warranty.
    Android Lurker Harley man's Avatar
    Jun 2011
    Just got my g2x for little over 24 hrs so Far I am loving it . I have a little light bleeding on screen and the phone when you use it a lot gets warm and when charging have any others seen this were it get warm from use and charging or is a problem . And wish I had a better reception at my house but with the wifi calling not that big of a deal . But when I do get get 4 g the phone is fast . Love the hot spot mifi tried it with my iPad works good . I hope the update helps with the reception or if that's a tmobile thing . So Far has not rebooted . I really like it so far just looks good and works real good .
    El Paso, TX
    59 times
    _B0BB0_
    The heating up is normal. It should feel warm to the touch under moderate/heavy use. If it is too hot to the point you cant hold it, then pull the battery. Normal temps are between 80F (idle) to maybe 110
    Somewhere on Kamino
    83 times
    Like xer said the heating a little is normal but, I would take it back because of the bleeding on the screen.
    Jun 2011
    I would if paid full price I got from Costco for 50.00 so light bleed not that big of a deal but if any other thing goes wrong then it's going back
    Somewhere on Kamino
    83 times
    Take it back to Costco anyway. $50 or $500 it's your money and two years with the carrier.
    197 times
    FurryVarmint
    You have a 1-year warranty against defects or failure. Get an exchange.
  1. USB problems!!!
    By Davita Tatishvili in forum Samsung Vibrant
    Last Post: 02-01-2011, 01:34 PM
  2. App problems on fascinate
    By Jvandyke13 in forum Samsung Fascinate
    Last Post: 01-27-2011, 05:41 PM
  3. Motorola Atrix Problems ?
    By danDroid in forum Motorola Atrix
    Last Post: 01-25-2011, 06:45 PM
  4. email problems
    Last Post: 10-26-2010, 04:57 PM
  5. Help--I have two problems!
    Last Post: 09-03-2010, 08:59 PM
call clearing is on going try again
galaxy g2x makes niose
group chat not working lg g2x
how to fix error code 1706 on lg g2g
lg g2 alarm not working
lg g2 not powering on
lg g2 screen not turning on
lg g2 shut off and won't turn back on
lg g2 wifi won't turn on
lg g2 won't turn on
lg g2 wont turn on
lg g2x stuck on 2g
lg p999 no network solution
lgg2 issues getting texta
what causes a lg gx2 phone from turning on
