G2X Problems
This is a discussion on G2X Problems within the LG G2x forums, part of the LG Android Phones category; So I bought a G2X to try out. I was upgrading from a G2. The G2X is really fast at browsing and the screen works ...
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: G2X Problems
    Android Lurker Abacus's Avatar
    Apr 2011
    G2X Problems
    The G2X is really fast at browsing and the screen works well. The problems I am having are it will not run "Speed Test" at home. I can have my G2 on wifi next to it and that phone performs flawlessly. The GTX says no network connection. The G2X will surf the web in the same test area so maybe its sometype of software issue.
    The 2nd more important problem is while it was on charge with wifi and 4G enabled,it shut off/rebooted a few times. I found this odd for a new phone,so I turned both of those features off. I woke up this morning to find that the phone will not turn on. It gave the charging symbol last night while plugged in. I'm going to plug it in to my car charge on the way to work to see if my home charger is a problem.
    I am putting the Sim card back into my G2 and will return this phone today to try another one. Maybe I got a Friday model?
    Thanks for any input.
    El Paso, TX
    59 times
    _B0BB0_
    hmm it does seems like a software issue. If ya just got it, then I would do the same thing and take it back. Let them send it back and reflash the software for someone else and get a new one.
    Android Lurker simonb1612's Avatar
    Apr 2011
    I too have experienced problems turning on the phone. several times when plugged in to recharge the phone would just shut down on its own and not start up again. I would have to unplug the charger, remove the battery and replace it, then try to turn the phone on again. When the phone did come on it did not appear to have charged. Eventually I returned the handset for another one.
    No problems since getting the replacement but now my wife experienced a similar issue her phone was plugged in to recharge over night and would not turn on this morning. after repeating the battery out steps, she got it to turn on. However her battery was fully recharged. Is this likely to be a software or hardware issue?
    Somewhere on Kamino
    83 times
    It's software and take it back to the store. Droid-xer is right.
    Sent from my HTC HD2 using Android.net
    Apr 2011
    thanks for the assistance. Other than this issue the phones are great.
    Android Lurker lapinitoro's Avatar
    Apr 2011
    I'm having problems using video calls with yahoo. The front camera doesn't work. Any idea???
    Sent from my LG-P999 using Android.net
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Quote Originally Posted by lapinitoro View Post
    Front facing cam support isn't a normal part of Android 2.2... You might have to wait on an update for compatibility with Yahoo Messenger. When Gingerbread rolls around, it brings native front facing camera support.
    Somewhere on Kamino
    83 times
    That is the reason why it's not working. The 2.2 for g2x doesn't support the front facing camera. At least for video chatting.
    Sent from my T-959 using Android.net
    Android Lurker fcjasontt's Avatar
    I too am having problems with the phone shutting off on its own. I found a setting that doesn't allow the screen to go into standby while on the charger. So that helps as far as making sure my alarm will go off in the morning but does not help the random shutting off even if it is not on the charger.
    Going to get on the horn with T-Mobile tonight and see if they have a remedy. If not she is getting exchanged.
    I have to say though, I love how smart the auto text thing is. Almost like this thing can read my mind even though I am severely screwing most of these words up.
    Somewhere on Kamino
    83 times
    The g2x had some problems and T-Mobile is aware of it.
  1. USB problems!!!
    By Davita Tatishvili in forum Samsung Vibrant
    Last Post: 02-01-2011, 01:34 PM
  2. App problems on fascinate
    By Jvandyke13 in forum Samsung Fascinate
    Last Post: 01-27-2011, 05:41 PM
  3. Motorola Atrix Problems ?
    By danDroid in forum Motorola Atrix
    Last Post: 01-25-2011, 06:45 PM
  4. email problems
    Last Post: 10-26-2010, 04:57 PM
  5. Help--I have two problems!
    Last Post: 09-03-2010, 08:59 PM
call clearing is on going try again
galaxy g2x makes niose
group chat not working lg g2x
how to fix error code 1706 on lg g2g
lg g2 alarm not working
lg g2 not powering on
lg g2 screen not turning on
lg g2 shut off and won't turn back on
lg g2 wifi won't turn on
lg g2 won't turn on
lg g2 wont turn on
lg g2x stuck on 2g
lg p999 no network solution
lgg2 issues getting texta
what causes a lg gx2 phone from turning on
