(SOS) LG Optimus Q L55c Boots into CWM-Based Recovery no matter what I do.
This is a discussion on (SOS) LG Optimus Q L55c Boots into CWM-Based Recovery no matter what I do. within the LG Optimus Q L55c forums, part of the LG Android Phones category; First I'm new to the forums I'm also new to this Optimus Q so far I am enjoying both of them, OK I still can't ...
Thread: (SOS) LG Optimus Q L55c Boots into CWM-Based Recovery no matter what I do.
    Android Lurker DatGreenTrashCan's Avatar
    Oct 2013
    First I'm new to the forums I'm also new to this Optimus Q so far I am enjoying both of them, OK I still can't figure this out, I've tried all kinds of Android forums and this is the first Q model based forum I've come across, the problem is I can't get it to do anything but boot into a CWM-Based Recovery,( I had flashed a rom to it and it was working till a few days later when it died and I turned it back on) if it is mounted as a storage device there are no files on the phone. The following are steps I have taken to attempt to fix it;
    -First in CWM-Based Recovery I selected the "wipe data/factory reset", "wipe cache partition", "wipe dalvik cache", "format system".
    -On my PC I placed the Striped_Q_Modv1.0 in the same directory as C:\Program Files (x86)\Minimal ADB and Fastboot as instructed
    -I ran Fastboot(in Administrator) on my PC with my LG Optimus Q plugged in with the proper USB cable and typed the following commands
    1.adb reboot bootloader
    * daemon not running. starting it now on port 5037 *
    *daemon started successfully*
    2.Then it restarted my phone and reloaded into CWM-Based Recovery, which confused me because it says next to "Once the device is in fastboot mode, verify your PC sees the device by typing fastboot devices" but after I typed "fastboot devices" it just leaves a small blank line and says C:\Program Files (x86)\Minimal ADB and Fastboot> with the input cursor flashing.(clearly something wrong there?)
    3. I decided to continue with the steps to see what would happen maybe it just wasn't popping up. so I typed "fastboot flash recovery Stripped_Q_Modv1.0.img"
    I just get "<waiting for device>"
    The sorce in which I am using to guide me through flashing on Fastboot is Here, an article by cyanogenmod, October 15 2013
    Could use some serious help I need a phone, Thanks for your patients with me I'm a noob at these things.
    518 times
    Welcome to the forum! I'll need you to hang on for a bit until one of our more knowledgeable members can check in with some advice on how to handle your problem.
  1. Optimus stuck on recovery screen
    By Pablo1992 in forum LG Optimus S
    Last Post: 07-01-2012, 04:31 PM
  2. {New Recovery} Raidzero's Custom SPR-based RZRecovery
    By huskerkate in forum Android Rooting
    Last Post: 04-21-2011, 06:05 PM
  3. Virgin Mobile Gets Android-based LG Optimus V
    By wicked in forum Other Carriers
    Last Post: 02-03-2011, 11:21 PM
  4. Custom Recovery for LG Optimus S
    By danDroid in forum LG Optimus S
    Last Post: 12-30-2010, 02:00 PM
boot cwm recovery lg l55c
boot lg 55c recovery
bootloader lg optimus q
bots on my lg optimus q
can't boot clockworkmod recovery lg optimus q
how do i get to bootloader lg optimus q l55c
how do i through the cwm based recovery for l55c
how do i wipe cache my lgl55c?
lg 55c cwm
lg l55c recovery
lg mytouch q stuck on logo screen
lg optimus q l55c cwm recovery
lg optimus q will not recovery mode
lgl55c does not reboot into custom recovery
limited space on lg optimus q l55c
