Hi I'm new and need help with my LG Optimus S
This is a discussion on Hi I'm new and need help with my LG Optimus S within the LG Optimus S forums, part of the LG Android Phones category; First of all, where should I post a question about it? I don't see a specific forum for LG phones... Thanks...
Results 1 to 9 of 9
Thread: Hi I'm new and need help with my LG Optimus S
    Junior Member mindykaybee's Avatar
    Member MajorKillin's Avatar
    You'll have to wait for them to create a specific group for it. But what kinda of problems are you having?
    Well I'm not having technical problems with it... it's user error really haha. Typing on it is a total chore. I would like to be able to text on a numeric keypad but I can't find an app for that. I received this phone as a Christmas gift and probably wouldn't have chosen it personally. Thanks for replying
    One of the awesome things about Android is that there are a TON on different input options you can try. Search the market for Smart Keyboard Pro. One of its functions is a T9 keyboard which will be like texting on an old cell phone with a strictly numeric keyboard.
    OOOH awesome! That's exactly what I want! Y'all are so helpful thanks!
    gvp
    gvp is offline
    Junior Member gvp's Avatar
    Quote Originally Posted by mindykaybee View Post
    usually where you can enter text, you can select the microphone and speak. I've found it to be quite accurate. For a video, select the microphone in the google bar at the top of the phone and select help/"watch a video".
    gvp
    gvp is offline
    Check out "voice actions". I've found it to be quite accurate. For a video, select the microphone in the google bar at the top of the phone and select help/"watch a video".
    Junior Member jmb1317's Avatar
    check out this forum its awsome forum for lg otimus s
    LG Optimus S - Android Forums
    especially read this thread- http://forum.androidcentral.com/lg-o...14-2010-a.html
    If you go to settings / language and keyboard/ swype settings /tutorial. Do the tutorial a few times. Then use the swype keyboard for a day you'll wonder how you ever used any other style keyboard.
how do i take the keyboard off one handed texting on lg optimus g pro
how do i turn of the back light on my lg optimus 9
how do i turn on the microphone on a lg optimus g pro
how do i turn the keyboard on for the optimus lg 9
how do you take off the taking keyboard on an lg optomist
how to delete words from android lg optimus phone for texting
how to take t9 off lg optimus
how to turn lg pro off
how to turn off predictive text on lg optimus
how to turn on predictive texting on lg aspire
lg optimus g pro predictive text turn on
lg optimus t9 keyboard
t9 keyboard on lg optimus
t9 on lg optimus
turn off predictive text lg e9800
