Custom ROM without using a computer?
This is a discussion on Custom ROM without using a computer? within the LG Optimus V forums, part of the LG Android Phones category; Is it possible to put a custom ROM (like cyanogenMod7) without using a computer? I was able to use Gingerbreak to root my phone, i'm ...
Thread: Custom ROM without using a computer?
    Android Jr Member HAT1985's Avatar
    Is it possible to put a custom ROM (like cyanogenMod7) without using a computer? I was able to use Gingerbreak to root my phone, i'm still using the stock ROM on my phone & I want something else...but don't have a computer to use.
    Sent from my VM670 using Android.net
    Administrator guidot's Avatar
    Massachusetts
    2 times
    guidot42
    If your phone is listed as compatible with ROM manager you can use it to flash clockwork mod recovery which will then allow you to install ROMs.
    I am not familiar with that specific phone so you will have to do some more research on whether RM and clockwork mod are compatible.
    Sent from my A855, while on the move.
    Thanks...i have ROM Manager & ClockworkMOD on my phone...i've already changed the font but anything else that requires I "Reboot into Recovery", does not work. It reboots and I get a blue error --suspend-- screen. I thought i'd be able to go into a manual recovery screen, regardless that I did the (easy one click) GINGERBREAK to root my phone...I even tried rebooting the phone a holding the power+camera+home buttons and Nothing gets me to that recovery screen... Just that blue error screen. I'm just surprised everything else works (like superuser, root check says its rooted, & I can do all things root) but not that.
    Should I just unroot it with Gingerbreak and do a manual/step by step root job on my phone instead?
  1. Computer Dictionary...somewhere
    By titanoman in forum Android Forum
    Last Post: 08-19-2011, 11:52 PM
  2. How to Transfer SMS from Android to Computer
    By Scien in forum Off-Topic Forum
    Last Post: 08-09-2011, 12:29 AM
  3. Transferring Information from Droid to Computer
    By Montymo in forum Android Forum
    Last Post: 01-17-2011, 05:46 PM
  4. why wont my phone connect to my computer
    Last Post: 10-14-2010, 10:04 PM
custom rom without pc
flash rom without pc
flash stock rom without computer
how to change rom without computer
how to create custom rom without pc
how to flash custom rom without pc
how to flash rom without pc
how to flash stock rom without pc
how to install a custom rom on any android without using computer
how to install custom rom on android without computer
how to install custom rom without pc
how to install stock rom without computer
how to make a custom rom without pc
how to make custom rom without pc
