Help Importing Contacts from SD Card
This is a discussion on Help Importing Contacts from SD Card within the LG Optimus V forums, part of the LG Android Phones category; So i recently had to reboot my phone, and i backed up all my apps and contacts by saving to the sd card. Unfortunately, after ...
Thread: Help Importing Contacts from SD Card
    Android Lurker iimltg's Avatar
    Apr 2012
    So i recently had to reboot my phone, and i backed up all my apps and contacts by saving to the sd card. Unfortunately, after trying to import my contacts numerous times they still do not show up in my contacts app but when i go to make a new message and search for a recipient, all my contacts show up as my options, they are just not located in my contacts folder. Its very annoying that all my contacts are saved onto the sd card, which i have double checked and they are on there still, but i cannot access them. What am i doing wrong? they are saved correctly, they just dont want to show up in my contact folder after importing.
    Also another problem i am having is my phone will not usb connect anymore, it does not recognize its connected to the computer but still charger while plugged in. how can i fix this? it worked fine before i rebooted the phone.
    340 times
    Hello there iimltg, and welcome to the forum. We are delighted to have you as a member!
    I'm afraid I can't help you with your questions (I'm not a technician), but we have a wonderful group of guys known as the Rescue Squad, and they WILL be able to answer your questions. You'll need to be patient and hang on for awhile, until one of the R/S can get free and swing by to give you a hand, but someone will be by.
    Welcome aboard buddy!
    Super Moderator Tears_for_Fears's Avatar
    Apr 2012
    196 times
    By rebooting, you mean factory reset?
    How are you importing/exporting The contacts? If your method doesn't work, you can try an alternative app in Google Play.
    For the second issue, make sure your USB settings are set and that your PC has all the necessary drivers.
    When people run in circles,
    it's a very very mad world.
    Tears for Fears
    ~~~ Guidelines of Conduct ~~~
    Android Lurker whistler7's Avatar
    Dec 2011
    North Carolina
    2 times
    Ditto on what Tears_for_Fears said. Did you factory reset your phone? and what file manager are you using because if your contacts are saved to you SD card and your file manager is still loaded then your contacts should show up but to my knowledge, any that were saved in the android contacts app will not.
  1. importing contact list from gmail
    By josesan311 in forum Samsung Galaxy S2
    Last Post: 11-25-2011, 06:54 AM
  2. Import/Export Contacts to SD card
    By amandanemode in forum LG Optimus GT540
    Last Post: 09-23-2011, 03:10 PM
  3. Importing Contacts?
    By n1nj4Lo in forum Rescue Squad Help
    Last Post: 05-26-2011, 12:25 AM
  4. facebook contacts and phone contacts
    By redfalcon302 in forum LG Ally Help
    Last Post: 12-16-2010, 01:41 AM
  5. Moving Items From Card To Card?
    By x9911 in forum LG Ally Help
    Last Post: 10-13-2010, 09:59 PM
can't get contacts off sd card
can't import contacts from sd card
contacts saved on sd card not showing
getting contacts from lg motion sd card
how do i get contacts from sd card to lg motion
how to import contacts from sd card lg motion
how to import contacts from sd card to computer
how to import contacts lg motion
how to import contacts to lg motion
how to transfer contacts from sd card to computer
how to transfer contacts to lg motion
importing contacts lg motion
importing contacts stopped android
lg motion import contacts
