Is There a Way to Get the Softkeys to Stay Lit Longer on the Sprint LG Viper 4G LTE?
This is a discussion on Is There a Way to Get the Softkeys to Stay Lit Longer on the Sprint LG Viper 4G LTE? within the LG Viper 4G LTE forums, part of the LG Android Phones category; I've noticed that the softkeys on the new LG Viper do not stay lit after you are in the menu and using the phone. It ...
Thread: Is There a Way to Get the Softkeys to Stay Lit Longer on the Sprint LG Viper 4G LTE?
    Editor in Chief dgstorm's Avatar
    711 times
    I've noticed that the softkeys on the new LG Viper do not stay lit after you are in the menu and using the phone. It means that you pretty much have to memorize the position of the home, menu, back, & search softkey buttons in order to tap them. Does anyone know of a way to get those softkeys to stay lit? I couldn't find anything in the settings that would help with that. Also, if there is no way to get them to stay on, is this something one of our amazing devs could create a custom "fix" for?
    Apr 2012
    230 times
    Does your Viper have such settings like "keyboard timeout"? That would be the fix. I don't know if such apps exist, but the devs can fix it on their ROMs.
    When people run in circles,
    it's a very very mad world.
    Tears for Fears
    ~~~ Guidelines of Conduct ~~~
    711 times
    Nope... I can't find a keyboard timeout feature at all. I think I've been through every setting on this phone.
    Android Lurker n0ve's Avatar
    Nov 2012
    I know this is a way old thread, anyway w/ the new ICS update, you can change the softkey settings...i personally turned mine off for battery life, but there's plenty of different timeout options.
  1. Replies: 0
    Last Post: 04-11-2012, 04:51 PM
  2. Replies: 3
    Last Post: 04-04-2012, 08:48 AM
  3. Replies: 0
    Last Post: 01-16-2012, 01:05 PM
  4. Replies: 0
    Last Post: 01-09-2012, 03:57 PM
  5. Sprint will no longer offer the Nexus One!
    By danDroid in forum Sprint
    Last Post: 05-11-2010, 09:22 PM
android how to button lights on longer
android lg keep keys lit
how do i keep the keys on android lit longer
how to keep android soft keys lit
how to keep keyboard on lg cell lit longer
how to keep the soft key lights on android
how to make bottom buttons on android stay lit
how to make toolbar stay lit on lg viper
keep soft buttons lit
keep soft keys lit
keep soft keys on
lg viper buttons
lg viper soft keys
lg viper soft keys flashing when plughed in
lg viper timeout
