Charging LED can be manipulated now?
This is a discussion on Charging LED can be manipulated now? within the Motorola Backflip Development & Hacking forums, part of the Motorola Backflip category; Does anyone know if we can manipulate the led at the charging port now that we have root? I can't find an app that works. ...
Thread: Charging LED can be manipulated now?
    Member mcpweev's Avatar
    forgot to tag, sorry
    Android Jr Member amingv's Avatar
    Well, I don't know about anything app-wise either, but you can control it through
    Code:
    /sys/devices/platform/pm7540-soc-leds.0/leds/messaging/brightness
    Not that it yields much practical use but it's a start, I suppose.
    I'm nowhere near code-smart enough, but if the AdjBrightness app can turn the menu/home/back buttons on and off, can an LED app be hacked to use them for message notifications and what-not? That might be preferable to using the charging LED.
    Member weasel5i2's Avatar
    Austin, TX
    Not sure if it's possible to manipulate the charging LED.. In getprop, ro.mot.hw.led is set to 0..
    --W5i2
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Adjbrightness from the market can turn it off, but not have it stay on. If you disable the lighting for the 3 capacitive buttons on the bottom, it also turns off the green side light.
  1. Acer announces Iconia Tab A500 - 10" Tablet with LTE
    Last Post: 01-05-2011, 11:54 AM
  2. Text (SMS) Message Drafts
    Last Post: 10-19-2010, 01:18 PM
android charging led
android charging light stays on
android dev turn on charging led
android off charging led
android turn off charging light
charging led for android
disable charge light droid motorola
disable g2 charging led
how to disable green charging light android
how to tufn on charging light for android
how to turn off android charge light
led android when charging
turn off charge light droid
use charge led for android
www.android.net 82894-charging-led-can-manipulated-now
