Junior Member
Rooting problem
I cannot seem to get J_r0dd's recovery image to load when i run my phone into recovery mode...and because of that...i can't continue on with the steps to root my phone. PLEASE HELP. i already downloaded and unzipped the recovery file and pasted it on my SD, but it still wouldnt work. please help.
10-08-2010 04:24 AM
# ADS
Member
Please Describe the step you are on..
And exactly what the problem is..
If you can get screen shots etc it would help.
Senior Member
The recovery image isn't required to root your phone. Actually you can't install his recovery image until after you have rooted the phone.
Member
Okay I might be wrong cause I never rooted a backflip... but I noticed you said you downloaded, unzipped, and put the files on your sdcard... where u supposy to unzip that file? Or leave it as is and put it on the root of your sdcard
HTC Aria Cyanogen 6 nightly (9/24/10) using Tapatalk Pro
HTC Aria... rooted
Clockwork recovery
CYANOGEN 7 Gingerbread
Overclocked to 805 MHz
Former phones...
HTC G1... that I have since rooted and gave to brother.
Motorola Backflip... many calls and replacements till they gave me the Aria
IPhone 3g... enough said
Junior Member
yes...i have finished rooting my phone, but i still cannot get it to load the recovery image.
am i doing something wrong?
Member
Originally Posted by
pnaymzb
Reallly?
Did you read the comments above?
What step are you on?
What is the exact error? Screen shots might be helpfull
Junior Member
I red the steps and instructions from M3, but i cannot get it to work. when i try to load j_r0dds recovery image...i get a picture with a phone and a triangle with an exclamation point on it. i know i rooted my phone successfully because when i load connectbot and type su i get a # instead of a $.
Member
Sounds to me like your phone's recovery hasn't been flashed from ADB properly. Also- maybe try re-downloading a fresh copy of the recovery image to ensure all bits are there. It could be that the image you're flashing to the phone isn't a complete image...
Sent from my MB300 using Tapatalk
Senior Member
Are you sure you followed all of the steps? Did you remember to remove the backup recovery? If not it will overwrite the custom recovery.
Member
pnaymzb
You don't have root... I am willing to bet you might have missed a rooting step. When you type su the root appreciate should fire up and ask for permission. Do you have the su app on the phone?
