Android Lurker
CyanogenMOD Won't Work Anymore
So here's the thing, I bought my backflip via Ebay, it came from AU, until here everything looks ok. 2 weeks ago i discovered that i can install the 2.3.7 android, with the cyanogenmod, so I did it. I followed every single step and it worked, installed radio update, the last cyanogen release and everything was ok, until the camera flip bug
So like a child I thought I could revert everything back, with the original system, I did the restore from the loader and the phone did the bootloop, then I flashed with the AU firmware and now I'm trying to install it again, tried everything but no luck :/ can you guys help me? Thanks
PS: I've noticed an strange bug, now after the factory flash every time I reboot my cellphone it does an factory reset (it turns on, get in android, then reboot again before I can touch something, it does a "reset" and my phone goes back to factory stats [ erases wifi and goes back to english { I'm brazilian } but the apps still there ] )
10-28-2012 07:37 PM
# ADS
Super Moderator
Wait, you're trying to flash your stock ROM or CyanogenMod?
Good to be back to the ol' Android.net
When people run in circles,
It's a very, very mad world.
Tears for Fears
Android Lurker
I'm trying to install the cyanogen again, but it only gives me the boot loop ( motorola "M" screen, then the android logo and then it reboots again)
Android Lurker
bro,
am running mine successfully...will foward u the link for step from 1 to zillion cant missed any of it.
Sent from my GT-N7000 using cyanogenMod9/rooted
Android Lurker
Super Moderator
I'm glad you've got it solved. Sorry that no one was able to assist you in time and thank you for posting the guide to fix this problem for other people who faved the same issue.
Tears for Fears
Android Lurker
There's the problem, I followed these steps one by one and get the M screen, android logo and then boot loop
Super Moderator
Oh, I'll see the steps, and get back.
Tears for Fears
Super Moderator
Try this one.
http://forum.xda-developers.com/show....php?t=1169116
Tears for Fears
Android Lurker
Tried but no luck :/ what "wipe-ext" actually does? After the factory flash (BACKFLIP & MOTUS firmwares Superthread [ Optus Australia 0.2.9]) with RSD Lite I can't install any android mod :/ all of them just give me the boot loop, I can root my phone, install the j_r0dd loader, wipe everything, install the rom, but after the reboot it only does the boot loop ( android screen, then reboot)
here's a video showing the problem
